Inventor Forum
Best Network Hardware?
5 REPLIES 5
137 Views, 5 Replies
We are planning some network updates and would like some feedback as to the fastest configuration for running inventor.
8 Inventor users (standalone installation)
All files stored on a network drive
Typical assemblies have 500 to 1500 parts
5 REPLIES 5
Do the (8) users normally work independently or do you share parts that are actively worked on ?? If you have standard parts that don't change, those don't apply, of course. Unless you can invest in gigabit hardware, I'd look at semi-isolated projects (it will copy the necessary files to your local PC so the initial file-open could be slow) or possibly Vault (it will do similarly).
Gigabit or fiber is the way to go...... building for future needs..
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
260-399-6615
Instructor/Author/Sr. App Engr.
AIP 11SP3, AIP 2008 SP1, PcCillin AV
HP zv5000 AMD64 ( modified)
Geforce Go 440, Driver: .8185, 2GB RAM
XP Pro SP2, Windows Classic Theme
http://teknigroup.com
wrote in message news:5704263@discussion.autodesk.com...
What about server hardware?
Should we have a dedicated Engineering server for the 8 users that then connects to the rest of the network?
If the server is only storing the files, no dedicated machine is needed, IMO.
Yes, engineering should have a dedicated server, espcially when creating and
using large assemblies. Even more important when running Vault or a shared
environment. I've seen companies where everyone was connected to the same
server, and at 4pm when they run reports in the office, engineering comes to
a standstill.
260-399-6615
wrote in message news:5704852@discussion.autodesk.com...
