Inventor General Discussion
toddg01
Message 1 of 3 (213 Views)
Bent tabs on radius using sheet metal
213 Views, 2 Replies
10-15-2012 08:02 AM
Is there a way to form tabs along a celendrical surface? We are trying to make a bottom of a round basket and we are trying to use the sheet metal portion of Inventor so we could create a flat layout but I can not seem to use an arch as a bendline. Is this the case? We are using IV 2011.
JDMather
Message 2 of 3 (210 Views)
Re: Bent tabs on radius using sheet metal
10-15-2012 08:06 AM in reply to: toddg01
Rolled Contour - a search here of the past couple of weeks should turn up example.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015-SP1 64-bit
toddg01
Message 3 of 3 (207 Views)
10-15-2012 08:11 AM in reply to: JDMather
Thanks. I will look into it. I was unsure where to even begin.
