Inventor Forum
Bent copper tubing not staying in place?
3 REPLIES 3
jyager
338 Views, 3 Replies
I tried doing several searches but maybe I'm not searching for the right question.
In routed systems, If I route "hard" pipe from one point to another, when I populate the route and go back up to the parent .iam level and try to drag the pipe it goes nowhere, this is good. If I try the same with the copper tubing, it'll stretch around all day long...I tried constraining it but that seems to just throw it all over too.
Is there a way to stop copper tube from stetching about?
Jason Yager
Inventor Professional 2023.2
Windows 10 Pro 21H2
Intel(R) Core(TM) i9-10900X CPU @ 3.70GHz
32GB RAM
AMD Radeon Pro WX 3200 Series
3D Connexion SpaceMouse Pro
3 REPLIES 3
lesmfunk
in reply to: jyager
I have been told to avoid the autoroute option in bent tubing. I manually draw and constrain my 3D sketch route to fixed objects and the tube doesn't move.
salariua
in reply to: jyager
I usually fully constrain my routes, or ground them. The geometry inside is adaptive, but the assemblies need not.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
