How the heck do I make a bent coil following an arc 90 deg.?
I do know how to make coil and helix, screws etc bur I cannot figure out how to make this coil
Bend Part
Attach your file here if you can't figure it out.
Yes Maria.
Unfortunately I do not speak Portuguese so I could not find anything in your blogs.
Would you be willing to send me the file?
Thanks in advance
I thought you only wanted to go 90°?
Bend Part would be far far easier.
This one was created using the bend part method. There are other ways of doing this that are more accurate (like the method Maria used), but if you just need a quick-and-dirty representation, the bend part method is great.
Thanks - good as far as it goes. I would still like to see Maria's solution
Cheers
Hi....here is!
Hi maria,
How can you think this?
it is a super way of helis
I celebrate you...
