Inventor General Discussion
Active Member
adavis
Message 1 of 17 (1,294 Views)
Bending round bar
1294 Views, 16 Replies
08-29-2011 12:03 PM
Can you let me know if you can bend round bar from the content center or if I have to use a spine or loft command.  I have inventor premium and do not have the piping and tube option.
thanks adria
blair
Message 2 of 17 (1,274 Views)
Re: Bending round bar
08-29-2011 01:17 PM in reply to: adavis
You should be able to use the "Bend"comand. You will need to create an Offset workplane tangent to the surface of the round bar. Create a Sketch, project the sides of the round bar, then create a line for your bend. You should then be able to bend the bar with the Bend command.
IV2015 up2 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
JDMather
Message 3 of 17 (1,263 Views)
08-29-2011 01:37 PM in reply to: adavis
You can Bend any part.  Source doesn't matter.
Attach your file here.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Active Member
adavis
Message 4 of 17 (1,231 Views)
08-30-2011 04:15 AM in reply to: blair
Thank you for your quick reply to my question.  I did try your solution earlier but it did not work.  I will try again maybe my work plane was not placed correctly.
JDMather
Message 5 of 17 (1,219 Views)
08-30-2011 04:39 AM in reply to: adavis
Attach your file here.  I don't think you can place workplane "incorrectly" in such a way that Bend Part won't work.
Valued Contributor
chrisw01a
Message 6 of 17 (1,211 Views)
08-30-2011 05:02 AM in reply to: blair
I can't get this method to work either.  I drew up a 1" round x 10" long and put a tangent work plane and then drew a line perpendicular to the edges and you cannot select that line using the "bend" command.
JDMather
Message 7 of 17 (1,208 Views)
08-30-2011 05:04 AM in reply to: chrisw01a
Attach the file here.
Valued Contributor
chrisw01a
Message 8 of 17 (1,198 Views)
08-30-2011 05:34 AM in reply to: JDMather
Here you go.
*Pro
sbixler
Message 9 of 17 (1,189 Views)
08-30-2011 05:52 AM in reply to: chrisw01a
Your part is in the sheet metal environment, which is intended to work with uniform thickness materials (sheet metal, for instance).  The Bend tool is in the normal modeling environment, and if you change over to that environment, you will be able to bend your bar using the sketch you created.
Valued Contributor
chrisw01a
Message 10 of 17 (1,181 Views)
08-30-2011 06:17 AM in reply to: sbixler
So it is.  I got it to bend.  Is there a way to "flatten" that out now for placement on a drawing showing the full length of the part then?
Thanks alot.
