Inventor Forum
Bending An sheet metal part
5 REPLIES 5
1241 Views, 5 Replies
Hi friends,
I want to bend the sheet metal part as on 90deg
I have tried using bend and Fold tool but it dose not produce the right model as desired.
please let me know if you have come across any situation like this before & how to overcome
Kindly refer to the attachment for the screen shot  of the part
thanks & Regards
5 REPLIES 5
the inventor file can also be found in the atachment
you can model this with the contour roll command first, then an extrusion.
See attached 2013 inventor part
Cheers
Mark
JDMather
Where did you get the image in your attachment if you don't know how to create the model?
BTW - Dan Banach's part can be done using only sheet metal tools, you don't need to Extrude.
Look in Help for Rolled Contour and Contoured Flange.
in reply to: JDMather
Hi JD,
I have just re-created the sheet metal part emulating your work flow after seeing your feature history tree picture, so much easier than my first attempt. All these little things make it easier in our day jobs.
Many thanks
MarkSmiley Very Happy
JSinghEBYHL
Thanks Danial it all worked out
