Inventor Forum
Bending An sheet metal part
5 REPLIES 5
amd
1226 Views, 5 Replies
Hi friends,
I want to bend the sheet metal part as on 90deg
I have tried using bend and Fold tool but it dose not produce the right model as desired.
please let me know if you have come across any situation like this before & how to overcome
Kindly refer to the attachment for the screen shot  of the part
thanks & Regards
5 REPLIES 5
amd
in reply to: amd
the inventor file can also be found in the atachment
Mark.Downes
in reply to: amd
you can model this with the contour roll command first, then an extrusion.
See attached 2013 inventor part
Cheers
Mark
Cheers
Mark
Inventor 2018, 3DS Max 2018, Vault 2018
JDMather
in reply to: amd
Where did you get the image in your attachment if you don't know how to create the model?
BTW - Dan Banach's part can be done using only sheet metal tools, you don't need to Extrude.
Look in Help for Rolled Contour and Contoured Flange.
Mark.Downes
in reply to: JDMather
Hi JD,
I have just re-created the sheet metal part emulating your work flow after seeing your feature history tree picture, so much easier than my first attempt. All these little things make it easier in our day jobs.
Many thanks
MarkSmiley Very Happy
Cheers
Mark
JSinghEBYHL
in reply to: amd
Thanks Danial it all worked out
