not sure if i have even used the correct technique but how do i perform the bends in the flat bar so as the bottom and top section are vertical and the small mid section is on the angle.At the moment the mid section is displayed vertical when using the cub please see attached files
Cheers,Dane
INV-2012
Solved by JDMather. Go to Solution.
Forget about using Folds.
Use Contoured Flange.
See attached
