Inventor Forum
Bend?
3 REPLIES 3
148 Views, 3 Replies
Bend?
See file CF, Thanks Bob
3 REPLIES 3
>See file CF
Can't find it?
It helps, if you send the file. I forgot to zip it. Bob
Bob,
There is no problem with the edges being of different lengths. The bend
will basically be the same width as the shorter length. However as the
edges are not parallel the bend will not work. To make them parallel just
project geometry from the 1st sketch to the 2nd and use the parallel
constraint. I've attached as screen shot as I'm using IV10.
Cheers,
Rob Singlehurst
Quadro4 750XGL 81.64
Athlon XP 2600+
1G RAM
W2K SP4
IV10 SP1
"Bob Johnson" wrote in message
news:5047632@discussion.autodesk.com...
