Just an example...
Are you using 2017? The attached part is drawn in 2017. If so, your Relief Depth "B" and Relief Width "A" will be dictated by the thickness of your metal. For instance, with a thickness of .125 and using a k factor of .43 and Bend Radius of .08 your Relief Width "A" will be .210 and your Relief Depth "B" will be .205. Now, change the thickness of your metal to .0625 and your k factor to .38 your Relief Depth "B" will change to .143 and Relief Width "A" to .163.
In earlier versions you could dictate those values in your Sheetmetal Default but in 2017 it will not allow it.
Thank You,
Tonya Sweeting
