Show only
Search instead for
How do I measure the radius of a bend in a STEP-file? I've tried the measure distance tool, but it only measures the shortest distance between two points.
Depending on the file, the arc can be segmented or a spline as mentioned. The simplest route is to put it in a idw to get the dimensions you need by some 2D method. I often use this method for "nearest" distances between two curved surfaces.
----------------------------------------------------------------------------------------- Autodesk Inventor 2019 Certified Professional Autodesk AutoCAD 2013 Certified Professional Certified SolidWorks Professional
