Harold,
So are you going to do what Seth talks about in the post you attached in a hotfix or SP1?
IMO I fully agree with Brett/theo bot and the ability to annote on the backface IS required and SHOULD show the correct direction for bends.
I would consider this a BUG or another half finished feature by Autodesk.
I don't write coding but come on how hard could it be
Write some coding for the drawing stating that if the backface view is selected that anytime the benddirection is down the you write benddirection value as up and if benddirection is up then you write benddirection value as down.
