Inventor Forum
Bend Geometry passes through the bend axis
5 REPLIES 5
tabsmith03
1817 Views, 5 Replies
Can anyone help with the attached part?  I need to create a flat pattern for this part, but it gives the error "Could not build this FlatPattern : Bend geometry passes through the bend axis.
Tabitha
Tabitha Smith
5 REPLIES 5
mdavis22569
in reply to: tabsmith03
I'm finding the bottom is at Corner 13 and 15 ... might want to make that a flange there ..also Cut 1 and 2 gave a problem ... I wish I could spent more time on it ...but I had a few minutes to look at it at lunch and that's where I found the start of the flat pattern issue
Mike Davis
mdavis22569
Someone will be able to show you right I'm sure ..they will remodel I should say for you too see exactly the issue..
Mike Davis
mpatchus
When requesting help and posting parts, it is always a good idea to include what version of the software you are using.
Not everyone is using the latest version of Inventor and cannot open parts made with a newer release.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
johnsonshiue
Hi! Corner13 and Corner15 seem to make the sheet metal part fail to unfold. There faces merged becaused of the corners. Could you take a look?
Thanks!
Software Test Engineer
tabsmith03
Thanks everybody for the help! I was able to change the angle on the two cuts at Corners 13 and 15 and that solved the problem.
Tabitha Smith
