Inventor Forum
Bend extents not visible
7 REPLIES 7
Message 1 of 8
1338 Views, 7 Replies
Hi guys/girls,
I have unfolded a 3D model into a flat plate, however the bend lines/extents do not appear in ISO.dwg
I doubled clicked into the view to access 'Display Options'. However, I canot tick the box to display bend extents as this option is shaded out (refer to attached screendump).
Can you all please assist. Thanks.
7 REPLIES 7
Message 2 of 8
-niels-
How did you unfold your model?
Is the view you placed a view of the Flatpattern?
If possible, can you attach your model?
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Message 3 of 8
CCarreiras
Hi!
In the table you shown in your post, activate the option: Tangent Edges.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
Message 4 of 8
in reply to: -niels-
Attached is my model Niels.
I used the 'unfold' command under the Sheet metal tab. Then I saved the unfold as a separate file (also attached).
Appreciate your swift reply. Thanks.
Message 5 of 8
in reply to: CCarreiras
Thanks Carlos. Is there any way I can also display the centreline? Activating the Tangent Edges seems to only display two parallel lines but no centreline...
Message 6 of 8
JDMather
All wrong.
Do not create a separate part.
Do not use the Unfold command for this.
In the original part file use the Flat Pattern command.
You now have a folded state and a Flat Pattern state in the same ipt file.
In the drawing choose option for Flat Pattern and/or Folded states when placing the views.
The Unfold/Refold commands are used to create features in flat state that cannot easily be created in folded state, they are not intended for creating Flat Patterns for drawings.
Message 7 of 8
in reply to: JDMather
Yes that worked! Thanks JDMather.
Message 8 of 8
Thanks for the help everyone.
