Read my reply to Troy, that should get you started...
T. Ham
Mechanical Engineer
CDS Engineering BV
Dual Pentium XEON 2.2 Ghz
2 GB SDRAM
NVIDIA QUADRO4 700 XGL (Driver = 77.18)
18 GB SEAGATE SCSI Hard Disc
3Com Gigabit NIC
Windows 2000 Professional SP4
Autodesk Inventor Series 9 SP4
Autodesk Inventor Series 10 SP3a
"Poul Skadborg"
wrote in message
news:5067883@discussion.autodesk.com...
Inserting Model or User Parameters in a note just moves the problem from the
idw to the part.
If the bends are made with the Flange command then the angle is a known
input. But if it is made by creating faces on a lofted, sloped, part, then
the angle is unknown to the designer.
You could say that the bend angle is an output from the design i stead of an
input.
As I read the answer from Steve Dennis (Autodesk) I just have to wait for a
new version.
Thanks for input!
Poul Skadborg
