Inventor Forum
Bend angle macro decimal point (VBA)
6 REPLIES 6
907 Views, 6 Replies
Hi all. I have a short macro to add the compliment angle to all the bend angles on an Inventor 2014 drawing. I want it to always show one decimal point on the compliment angle, but if that would be '0' then it doesn't show it. I.e. in the attached picture I want it to be 58.0 (122.0) DOWN. I've attached the code here. Anybody have a suggestion?
Thanks!
Nathan
Sub Test()
    Dim oDoc As DrawingDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oView As DrawingView
    Set oView = oDoc.ActiveSheet.DrawingViews(1)
    Dim oNewDimStyle As DimensionStyle
    Set oNewDimStyle = oDoc.StylesManager.DimensionStyles.Item("RASOR")
    Dim oNote As BendNote
    Dim sTemp()  As String
    Dim sTemp1() As String
    Dim iAngle As Double
    For Each oNote In oDoc.ActiveSheet.DrawingNotes
        If oNote.Type = kBendNoteObject Then
            sTemp = Split(oNote.Text, " ")
            For i = 0 To UBound(sTemp)
                If InStr(sTemp(i), "°") > 0 Then
                    iAngle = CDbl(Split(sTemp(i), "°")(0))
                    If InStr(oNote.FormattedBendNote, "(") > 0 Then
                        sTemp1 = Split(oNote.FormattedBendNote, "(")
                        oNote.FormattedBendNote = Replace(oNote.FormattedBendNote, Split(sTemp1(1), ")")(0), CStr(180 - iAngle))
                        oNote.DimensionStyle = oNewDimStyle
                    Else
                        oNote.FormattedBendNote = Replace(oNote.FormattedBendNote, "</BendAngle>", "</BendAngle>" & "(" & CStr(180 - iAngle) & ")")
                    End If
                    Exit For
                End If
            Next
        End If
    Next
End Sub
6 REPLIES 6
cwhetten
It seems to me that this would be controlled by your dimension style called "RASOR".  You would need to edit the RASOR dim style and set the angular dimension precision to 1.1 and turn on the option for trailing zeros:
This would best be done in your template, but you could perhaps write some additional lines of code to modify the dim style.
Cameron Whetten
Inventor 2014
in reply to: cwhetten
Cameron,
Thanks for the reply. My RASOR style is already setup exactly like you show. Honestly, I was hoping I forgot to check the trailing zeros box, but that doesn't seem to be it.
Nathan
cwhetten
Hi Nathan.  Can you repost the image from your first post, but in higher resolution?  I can't read it.  This is what I see:
It would help me understand exactly what your code is doing.
Thanks.
Cameron Whetten
Inventor 2014
Sorry about that. Let's see if this one is any better.
cwhetten
OK, I figured something out.
Instead of the Cstr( ) function, use the Format( ) function.  So, for each instance of CStr(180 - iAngle) in your code, replace it with Format(180 - iAngle, "###.0").
I tested it and it seemed to work.  Give it a try and post back.
Cameron Whetten
Inventor 2014
Please click "Accept as Solution" if this response answers your question.
Worked perfect. Thanks!
