Inventor General Discussion
517 Kudos
Post 41 of 98
Re: Benchmark for Autodesk Inventor 2012
11-04-2011 09:08 AM in reply to: prusas
Here is my results for the 1000.iam test.  I compared 2011 and 2012.  Same machine.. similar application option settings.  If 15 is the refresh rate we are after, 2011 would do about 650 parts, 2012 is down to 525. A drop of about 20%.
658 Kudos
Post 42 of 98
11-04-2011 12:10 PM in reply to: karthur1
ah ha.. Got it.. (Display Silhouettes should be turned off)
400 parts 15.2Hz refresh rate at 1920 x 1080 resolution. (quality hardware mode)
400 parts 15.8Hz refresh rate at 1920 x 1080 resolution. (performance hardware mode)
400 parts 15.95Hz refresh rate at 1920 x 1080 resolution (compatibility hardware mode)
 I had "display silhouettes" turned on (default is off). As soon as I turned it off I went from 200 to 400 parts at 15Hz..
:smileyvery-happy:
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
Distinguished Contributor
1 Kudo
Post 43 of 98
11-04-2011 12:46 PM in reply to: mcgyvr
Silhouettes are turned on in both 2010 and 2012 in the results I show below.
IV2012 is still a dog when compared to IV2012 D3D 10.
However I did 500 parts with sihlouettes off in IV 2012, here are the quick results:
Quality, 500 parts, 1920 x 1200  16.39 Hz
Performance, 500 parts, 1920 x 1200 16.67 Hz
Compatability, 500 Parts, 1920 x 1200 16.95 Hz.
Also, I have dual 1920 x 1200 displays, not sure how that affects results since the only part of Inventor on the second monitor is the browser bar.
23 Kudos
Post 44 of 98
11-04-2011 12:58 PM in reply to: mcgyvr
... Just to add to the numbers
Hits 15 Hz at 400 parts, although I noticed that if zoomed in the Hz went up.  Evens out at 15-ish after the entire assembly is in view and spinning.  Zooming out further doesn't change anything.
my vital statistics...
Windows 7 64 bit
Intel® Core™ i7 CPU 860 @ 2.8GHz; RAM 8Gb
Hard drive (300 GB)
NVIDIA Quadro 4000; Samsung SyncMaster 2343 - 2048 x 1142
Valued Contributor
8 Kudos
Post 45 of 98
11-05-2011 03:09 AM in reply to: vandargo
Summary of interim results
Windows 7 64 bit
Intel® Core™ i7 CPU X 990 @ 3,9; RAM 12Gb x 1600
OCZ-Vertex 4 SSD (119.24GB)
Asus NVIDIA GeForce GTX 580; PLE2607WS 1920x1200
Valued Contributor
8 Kudos
Post 46 of 98
11-05-2011 07:35 AM in reply to: prusas
During the summary, there was a suspicion that there may be misread the data. Therefore, if you have the opportunity, please submit the test data in a form.
Windows 7 64 bit
Active Contributor
4 Kudos
Post 47 of 98
11-05-2011 08:34 AM in reply to: prusas
And that test is more reliable? "Inventor 6 bench" is like a kinder for us...
_______________________________________________________
Windows7 64b; GIGABYTE EX58-UD5; Intel Core i7 920 (2.66GHz)
DDR3 3x2GB Kingston, HD ST 750GB+320GB
NVIDIA Quadro FX1800 (1680x1050) + SpacePilot PRO
APDSUltimate 2014
Valued Contributor
8 Kudos
Post 48 of 98
11-05-2011 09:43 AM in reply to: malenki
300 part -
Shaded
manual                    32Hz
Inventor 6 bench    36,5Hz
Hiden
manual                    4,9Hz
Inventor 6 bench    8,8Hz
 Wireframe
manual                    27Hz
Inventor 6 bench    26,6Hz
but "Inventor 6 bench" exactly the same is not valid for all users
Windows 7 64 bit
Valued Contributor
8 Kudos
Post 49 of 98
11-05-2011 11:09 AM in reply to: prusas
interesting coincidences
Windows 7 64 bit
Valued Contributor
7 Kudos
Post 50 of 98
11-05-2011 11:19 AM in reply to: karthur1
I ran my home PC to see how it handled the same.
I got approx. 460 parts (shaded with edges) at 15Mhz.
System is the following
AMD Athlon II X3 445 3.11Ghz
8GB DDR1600
NVIDIA GTX 560 Superclocked 2GB
1680x1050 Resolution
Windows 7 x64
Michael Benoy
Designer
Scott Safety
Inventor 2013 Pro, Windows 7, 64bit
Intel® Xeon® Processor W3580 (8M Cache, 3.33 GHz)
12 GB DDR3, NVIDIA Quadro FX 3800
