Inventor General Discussion
New Member
ACcanopy
Message 1 of 11 (392 Views)
Beam is becoming skewed/distorted in assembly
392 Views, 10 Replies
05-01-2012 07:50 AM
Hi I'm Alex and I am new to Inventor. We just switched to Invetor From CAD and have been learning as i go mostly. I have been experiencing problems that are leading to major setbacks due to requireing me to redraw multiple items.  With my job we have to use wide flange beams and square columns etc... I'm able to draw the indidviual parts and at times have no problem with anything being offset, crooked, skewed or anything. But I find that I'm duing something in the assembly process that is causiing my parts to become skewed/distorted in the assembly and thus also on my view layouts for prints.
If anybody can help me with this problem i would greatly appreciate it!!!
Thanks again guys.
Alex
*Expert Elite*
JDMather
Message 2 of 11 (389 Views)
Re: Beam is becoming skewed/distorted in assembly
05-01-2012 08:03 AM in reply to: ACcanopy
Your first part in an assembly should be grounded.
If you unground it and move it around your views will become skewed.
This can be fixed, but let's see what you really have.
Attach your files here.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
New Member
ACcanopy
Message 3 of 11 (386 Views)
05-01-2012 08:06 AM in reply to: JDMather
Thanks for the response. I would love to attatch a file but we have an elevated confidentiallity contract and i cannot post any business work on here. Believe me i wanted to be able to show exactly what is happening but instead have to talk my way through it.  When you say ground it what do you mean and how do you do that?
Distinguished Contributor
kstate92
Message 4 of 11 (371 Views)
05-01-2012 11:03 AM in reply to: ACcanopy
Constrain the part to the pricipal work planes, axes, and origin point in the assembly file until it has zero degrees of freedom (can't move it by dragging).  When you start with a blank iam file and insert a part, the first part is (always?) automatically constrained.  You then constrain the subsequently inserted parts to the first part (or the assembly origins if you wish).
KState92
Inventor Professional 2014 64 SP2
Windows 7 Pro 64 bit - SP1
Xeon E5-1620
16 GB Ram
Quadro 4000
*Expert Elite*
mcgyvr
Message 5 of 11 (361 Views)
05-01-2012 11:45 AM in reply to: kstate92
always automatically grounded.. (not constrained)
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
Valued Contributor
JohnK_TEDCF
Message 6 of 11 (355 Views)
05-01-2012 11:54 AM in reply to: ACcanopy
Since your just starting out with Inventor, you might want to check out these free tutorials:
http://www.youtube.com/user/TEDCFPublishing?feature=mhee
I think they might help you out!  If you have any questions about training for Inventor, feel free to contact me.
John Koop
Software Engineer/ Inventor Specialist
TEDCF Publishing
www.trainingtutorial.com
*Expert Elite*
JDMather
Message 7 of 11 (338 Views)
05-01-2012 02:02 PM in reply to: ACcanopy
ACcanopy wrote:
 I would love to attatch a file but we have an elevated confidentiallity contract and i cannot post any business work on here. Believe me i wanted to be able to show exactly what is happening.....
Do you have a home computer?
Can you download a 30-day trial and make something up that exhibits the same behavior that you are seeing in your proprietary work.  It is much easier to communicate with actual geometry files.
Member
7997redtail
Message 8 of 11 (105 Views)
05-21-2014 10:25 AM in reply to: JDMather
A couple of points.
I am a school teacher and this is the first year we have had this "crooked" views problem.  We, meaning the kids and I have two solutions of which the second is by far the best.
Before I get to the solution I would like to point out that the first part put into an assembly is not always grounded.  Or, in our case, its never grounded.  Anyone know why not?  All other years it has been so i think maybe the installers have changed something.
As for the solution, the one above, constraining to planes, works well but not always.  If the planes show up in "red" when you go to select them it will work.  If they show up in "White" you won't be able to select them.  We have not been able to figure out why they are white sometimes and red others.  Anyone know why?
The best solution is to;
While in the assembly view
    select the "view" tab
    Go to the "navigate" section on the far right
    Choose the "look at" option
    Select the face of your object you want to be the front.
        The object will rotate into a square view facing you
    Right Click the view cube
    Choose the option to set the current view as front view
Go back to your drawing and the view will be correct and straight.
Hope this helps.
*Expert Elite*
blair
Message 9 of 11 (92 Views)
05-21-2014 11:39 AM in reply to: 7997redtail
ADSK added the ability upon placement of the first part by RMB when placing the part brings up a dialogue box that allows you to rotate the part about a number of axis as well as the option to Ground at Origin. You can over-ride this within the Tools>Application Options>Assembly>Place and Ground first part at Origin.
IV2015 SP1 PDSU / Sim Mech 2015 r1 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 344.75
SpacePilot Pro 10.2.0 / 17.2.0.11011 / 4.17
Delta Tau Chi ΔΤΧ
kstate92
Message 10 of 11 (78 Views)
05-21-2014 01:04 PM in reply to: blair
Maybe it's just me, but I swear both this option (Ground at Origin) and Do Not Edit Placed Dimensions in idws occasionally become unchecked on startup, even without an iPoof (crash) having happened.
KState92
Xeon E5-1620
16 GB Ram
Quadro 4000
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
