I am using beam/column calculator in the frame generator in inventor 2010 suite.
I have a beam being used for a flight of stairs it is positioned 40 deg above the 'floor' or my xy plane in my assembly.
I want to place a distributed load acting as if there were several people stading on the stairs at one time so in the direction of the z axis of my assembly.
The problem I am having is I try to change the angle of the distributed load but it only allows me to change the x and y components of the load. You can see this in the screenshots i took.
Is there a way I can:
a) change the angle of the laod in the Z directions
or
b) change the cordinates in beam itself so the x axis is along the length of the beam instead of the z axis.
I have tried adding a UCS to the beam part but it still wants to choose the length of the beam as the z axis.
Any help would be greatly appreciated.
Matt
Solved by cwhetten. Go to Solution.
I'm not sure what all of the options are in the beam calculator, but you could do this by splitting your load into a Y component and an axial load component (Z component). So in effect, you will have two loads applied. One for the vertical Y component of the total load, and an axial load for the Z component. Does that make sense?
Select/Check the Vector box in the Load dialogue box. You can then enter in your load vectors, or create a work axis and use it for load direction. I believe you can even use a Work-Axis to define the load direction (still need to "Check") the vector box.
Sorry, I was thinking of either analysis in model or frame-gen.
There is no vector box to 'check' i think that is a feature of the stress analysis found in the 2010 pro version, which i unfortunately do not have. I am using the beam/column calculator found in the frame generator feature of the 2010 suite version.
This will work, i just was hoping to avoid breaking up my applied load into axial and shearing loads, i know that is lazy of me, thanks for the help!
Matt
