Inventor Forum
Batch solution for IDW files that cannot be viewed with Volo View?
2 REPLIES 2
137 Views, 2 Replies
In knowledge base article TS68955 dated May 31, 2002, Autodesk acknowledges
a problem with some IDW files when being viewed with Volo View 2 or Volo
View Express 2.
Autodesk noted that if an IDW file contains a title block that includes the
filename and Volo View 2 reports an error when reading the file, you can use
the following procedure to work around the problem:
1.. Open the drawing in Autodesk Inventor 5.
2.. Delete the file name from the title block and recreate it.
3.. Save the drawing.
The problem is that I have several hundred such files and this will be very
time consuming to correct. I desperately need some sort of batch style
solution to correct the problem en masse rather than a file at a time.
Has Autodesk developed such a solution or can anyone suggest one?
The files were created using Inventor 5 although the original drawing
template was created in Release 4 and migrated to Release 5. I have tried
migrating these files to Release 5.3 but the problem persists. Any
suggestions would be sincerely appreciated.
Michael
2 REPLIES 2
dmatsalla
There is a service pack coming out next week. It should cure your problems.
Thank you for responding!
Is the service pack for Inventor 5.3 or Volo View?
Sincerely,
Michael
"dmatsalla" wrote in message
news:f11e9e3.0@WebX.maYIadrTaRb...
problems.
