Inventor General Discussion
Distinguished Contributor
0 Kudos
Post 1 of 6
Batch convert to PDF
1073 Views, 5 Replies
09-23-2008 08:39 AM
Sorry to post such a often repeated question, but the group search feature is not working and I have spent a few hours on this now, without any success.
In Inventor 2008, I know I can use the Inventor Task Scheduler to convert a bunch of inventor drawings into PDF's. However, I recall that it was not a straightforward process. The drop-down list where you might have chosen ".pdf" did not show ",pdf". I think you had to manually type it in.... well my memory is quite vague on what to do, and where.
How do you batch export PDF's?
Thank You,
Joe Dunfee
Employee
0 Kudos
Post 2 of 6
Re: Batch convert to PDF
09-24-2008 01:57 AM in reply to: cadcoke4
Hi Joe,
Please batch print the drawing as PDF with following steps:
1. Set Adobe PDF as your default printer
2. Set the correct printing preferences, the output folder should be [path]\*.pdf (see the attached screenshot)
3. Go to Task Scheduler, create a Print Files task to print drawing
Please Let me know if it helps.
Tim
Inventor Drawing Manager QA
Employee
0 Kudos
Post 3 of 6
Just a tips: please insure your drawings are not duplicated in file names.
Tim
Inventor Drawing Manager QA Edited by: zhonglin.nong@autodesk.com on Sep 24, 2008 4:59 PM
0 Kudos
Post 4 of 6
09-24-2008 07:14 AM in reply to: cadcoke4
Are you talking about using a system printer driver from Adobe? It doesn't show up as a pritner in my system printer, nor from within Inventor. However, we do have a 3rd party PDF system printer. So, I imagine that would be a good substitute... though I imagine the file size for the saved PDF's would be larger.
For some reason, I seemed to think there was another way. But, since my memory is so vague on this, I will just ignore those thoughts.
Thank you for the reply.
Joe Dunfee
Active Contributor
0 Kudos
Post 5 of 6
09-24-2008 08:04 AM in reply to: cadcoke4
If I SAVEAS a PDF, my output looks fine.
If I print to a PDF printer, I have banding as shown in the attached file.
Any suggestions?
Jason
Autodesk Inventor Suite 2009
Dell Precision 690 Mini-Tower
Quad Core Xeon Proc X5355 2.66GHz, 2 X 4MB L2 Cache 1333MHz
4GB, DDR2 ECC SDRAM Memory 667MHz, 4X1GB
USB keyboard
Dell UltraSharp 2407FP,Wide Flat Panel w/Height AdjustableStand,24.0 Inch VIS
nVidia,Quadro FX 3500,256MB dual VGA or DVI, Graphics Card
160GB SATA 3.0Gb/s, 7200RPM HardDrive with 8MB DataBurst Cache
C5- All SATA Hard Drives RAID 1 for 2 Hard Drives
Floppy Drive and Dell 13 in 1 USB Media Card Reader
WINDOWS XP PRO SP2, with MediaDell
USB 2-Button Entry Mouse with Scroll
48X/32XCDRW AND 16XDVD+/-RW w/Cyberlink Power DVD,Roxio Digital Creator
Sound Blaster X-Fi XtremeMusic(D), w/Dolby Digital 5.1
Dell A525 30 Watt 2.1 Stereo Speakers with Subwoofer (Black)
160GB SATA 3.0Gb/s, 7200RPM Additional HardDrive with 8MB DataBurst Cache
SATA/SAS integrated controller for Connecting Internal Hard Drives
Employee
0 Kudos
Post 6 of 6
09-26-2008 08:18 PM in reply to: cadcoke4
Hi Jason,
Please refer to the thread http://discussion.autodesk.com/forums/thread.jspa?threadID=693568
If it is no help, could you please send an email to zhonglin.nong@autodesk.com? I can
send you a secure ftp site to upload your dataset if possible.This will help
a great deal to look in to the issue that you are facing.
Tim
Post to the Community
New Post
