Inventor Forum
Batch Convert IDW to DXF
10 REPLIES 10
Message 1 of 11
792 Views, 10 Replies
I have seen a program to batch convert IDW to DWG. Is there one somewhere to
convert IDW to DXF?
Byron Newton
10 REPLIES 10
Message 2 of 11
Hmmm I am seeing a pattern here. It appears I should try to find time to write some
macros for IDW to DXF and MDTto IPT for my iBatchrun program.
Problem comes in finding the time. 8^/
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"Byron Newton" wrote in message
news:80604A346E6A66DA62BC88DA43F00654@in.WebX.maYIadrTaRb...
> convert IDW to DXF?
> Byron Newton
Message 3 of 11
You wouldnt happed to have a macro for IDW > DWF would you?
"Kent Keller" wrote in message
news:6EF76FAB9C7FF08E37CC3A73CAA7FD04@in.WebX.maYIadrTaRb...
to write some
> Kent
> Assistant Moderator
Message 4 of 11
No I don't . My guess is that all these things would only take a few lines of code, and
have very slight differences between them. If I get a chance in the next night or two I
will see what I can do. If I am not mistaken some of this stuff has probably been posted
to the Inventor.customization NG if a person were to search in there for it.
Kent
Assistant Moderator
"Paul Houlker" <666paulh@rimex.com666> wrote in message
news:08166BC6131ACEEC58E381F4569494A1@in.WebX.maYIadrTaRb...
Message 5 of 11
We are not far enough along in our IV implementation yet to need it (My MDT
one works great), but I saw the thread and thought i would ask.
Message 6 of 11
I Just changed the DWG convert macro from Kent Keller's site to do DXF late yesterday. I have done a few conversions to DXF but have not fully tested it. The few that I did seemed to be fine. If it is OK with Kent I will be happy to e-mail it to you and send it to Kent if he wants. Like the DWG, the DXF runs with Kent's batch run program.
Ken
kdale@kadway.com
Message 7 of 11
That would be great. If Kent approves of course.
Would it be possible to do the same for IPT to Sat?
Byron Newton
I
Ken
kdale@kadway.com
Message 8 of 11
Sure send away, I will add it to the page. 8^) From some help from Lars Nielson I know I
could do a DWF one, but he also told me he is close to releasing a Batch translator that
will do most variations of exports.
Kent
Assistant Moderator
"kadway" wrote in message news:f15bf01.4@WebX.maYIadrTaRb...
> Ken
> kdale@kadway.com
Message 9 of 11
Kent:
I have sent the DXF macro to you. I had just started to work on a step and sat translator macro to run with you batch program but it sounds like Lars is doing a much better one than what I was working on. Mine was just to get me by when I had a hundred or so to convert to step or sat.
Bryon, I did not see a e-mail for you but I assume that you will be able to get it from Kent.
Ken
Message 10 of 11
I will download it when Kent puts it on his web
site.
Thanks guys
Byron
Newton
Message 11 of 11
I have replaced the SaveasDWG macro with a SaveAs macro. It contains macros
to save to all the normal export file formats. All except for DWG and DXF
save using the system defaults only. DWG and DXF use a ini file if one is
set up for it .. right Ken?
Be aware, I can't even say for certain that I have tried each output (bmp,
igs, etc) in each file type (ipt, iam, idw, ipn), but what I did test went
without a hitch. Be sure to let me know if anyone does run into any that
don't work or have problems.
http://www.mymcad.com/kwik/iCode/icode.htm then click on the iBatchRun
link and finally at the bottom of the page, get the SaveAs Macros.
Enjoy.
Kent Keller
http://www.MyMcad.com/KWiK/Mcad.htm
Assistant Moderator
news:F197C2F30A30E2CD9C49DDF1D38A554A@in.WebX.maYIadrTaRb...
> I will download it when Kent puts it on his web site.
> Thanks guys
> Byron Newton
