Good Morning,
I've created a sheet metal part and have set my parameters. In using the fold feature, cannot create bend past 180 degrees. Radius is large enough (21") and sheet is long enough as there is still flat sheet after a 180 degree bend. How do you create bends past 180 degrees? Thanks for the help!
Darren
Solved by JDMather. Go to Solution.
Can you post the offending part.
I didn't take the time to exactly model your part - so check the dimensions.
You should use sheet metal tools for sheet metal parts (as a beginner) and almost never use Fold.
