style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">Just
want to know how is the best way to design in INV. I design sawmill
equipment(convoyor, step feeder,transfert...). By the past, I have made a bank
of material with iPart (square and round steel tube, shaft and other steel
shape, bolt, bearing).
The good thing with the iPart is the automatic BOM
creation and you have the adavantage of update ALL the BOM field when you
change any dimension on the part. But, you can't put the parts adaptive
because I use custom parameter for the lenght. Now, I have some problem (since
IV6) with my iParts (mainly the steel shape) that I can't fix and it's very
annoying.(see this thread:
href="http://discussion.autodesk.com/WebX?viewTopic@187.oyHCa1JZsGw.4@.f161f96!page=1&keywords=cl...
) By the way, I said in this thread that I fix my issue but finaly I have fix
the problem only in some of my iPart.....:-(
What I want to do now is to
make a bank of steel shape in different template. The main advantage is to be
able to use the adaptivity. I can make my template to create automaticly the
BOM but if you change something, the description can't update... I think to
use the iPart only for bolt, bearing and other manufacture parts
Brief, I
want to know how do you work and why ?? :0)
