I made a copy of an assembly along with the .ipn and .idw files to do a component replacement. After the replacement, all the components were updated in the .iam and .ipn files. However, in the .idw file, the base views of the .ipn does not fully update. As you can see in the attach document, the entire box is still red, while the updated components are grey. If there is a solution to this, I would greatly appreciate the help.
Thank you,
Keng
