Inventor General Discussion
Active Member
0 Kudos
Post 1 of 6
Base and Projected View Label Name to match Orientation Name
536 Views, 5 Replies
04-26-2012 08:38 AM
I would like to know if there is a way to have each view name to be set to the orientation names/ the 3D view cube's name. Is there a way to do this without manually changing each one?
Hi jbauer,
sorry, i was not aware that you wanted to use it in iLogic. The code above is for using as a macro in VBA.
I changed the code. Now you should be able to use it with iLogic:
Here is the code for iLogic:
Sub Main()
Dim odoc As DrawingDocument
odoc = ThisApplication.ActiveDocument
'active sheet
Dim tmpSheet As Sheet
tmpSheet = odoc.ActiveSheet
Dim tmpView As DrawingView
'every draring view
For Each tmpView In tmpSheet.DrawingViews
Dim myDrawingViewName As String
'Which text for which orientation
Select Case tmpView.Camera.ViewOrientationType
Case ViewOrientationTypeEnum.kBackViewOrientation
myDrawingViewName = "Back View"
Case ViewOrientationTypeEnum.kBottomViewOrientation
myDrawingViewName = "Bottom View"
Case ViewOrientationTypeEnum.kFrontViewOrientation
myDrawingViewName = "Front View"
Case ViewOrientationTypeEnum.kIsoBottomLeftViewOrientation
myDrawingViewName = "Iso - Bottom Left View"
Case ViewOrientationTypeEnum.kIsoBottomRightViewOrientation
myDrawingViewName = "Iso - Bottom Right View"
Case ViewOrientationTypeEnum.kIsoTopLeftViewOrientation
myDrawingViewName = "Iso - Top Left View"
Case ViewOrientationTypeEnum.kIsoTopRightViewOrientation
myDrawingViewName = "Iso - Top Right View"
Case ViewOrientationTypeEnum.kLeftViewOrientation
myDrawingViewName = "Left View"
Case ViewOrientationTypeEnum.kRightViewOrientation
myDrawingViewName = "Right View"
Case ViewOrientationTypeEnum.kTopViewOrientation
myDrawingViewName = "Top View"
Case Else
myDrawingViewName = ""
End Select
'Chang if view orientation was found
If Not myDrawingViewName = "" Then
'change drawing view name
tmpView.Name = myDrawingViewName
End If
Next
End Sub
Please use the button "Accept as Solution" if it works.
Thanks.
Product Support
4 Kudos
Post 2 of 6
Re: Base and Projected View Label Name to match Orientation Name
04-30-2012 07:55 AM in reply to: jbauer
Hi jbauer,
you could manage this with a little macro like this:
Sub OrientationToLabel()
Set odoc = ThisApplication.ActiveDocument
'active sheet
Set tmpSheet = odoc.ActiveSheet
'every draring view
    Case Else
    End Select
End If
Next
End Sub
 bofore:
After using the macro:
The macro will change the name of the drawing view of all view on that sheet.
You can adjust the code and replace the names of the orientation with names you like.
Do you think, this would work for you?
Dennis Ossadnik
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Active Member
0 Kudos
Post 3 of 6
04-30-2012 08:36 AM in reply to: jbauer
When I paste this code into the iLogic Browser, I get an error message. I attached a screenshot image of it.
Product Support
4 Kudos
Post 4 of 6
05-02-2012 01:04 AM in reply to: jbauer
Hi jbauer,
Sub Main()
'active sheet
'every draring view
    Case Else
    End Select
End If
Next
End Sub
Thanks.
Dennis Ossadnik
Active Member
0 Kudos
Post 5 of 6
05-02-2012 09:15 AM in reply to: Dennis.Ossadnik
Thanks for your help,
It's greatly appreciated.
3 Kudos
Post 6 of 6
11-07-2013 03:18 AM in reply to: jbauer
hi :smileyhappy:
work great, but is you have a section in your drawing, put side view in view label name????
