Base and Projected View Label Name to match Orientation Name
23 REPLIES 23
Message 1 of 24
3703 Views, 23 Replies
I would like to know if there is a way to have each view name to be set to the orientation names/ the 3D view cube's name. Is there a way to do this without manually changing each one?
23 REPLIES 23
Message 2 of 24
Dennis.Ossadnik
Hi jbauer,
you could manage this with a little macro like this:
Sub OrientationToLabel()
Dim odoc As DrawingDocument
Set odoc = ThisApplication.ActiveDocument
'active sheet
Dim tmpSheet As Sheet
Set tmpSheet = odoc.ActiveSheet
Dim tmpView As DrawingView
'every draring view
For Each tmpView In tmpSheet.DrawingViews
Dim myDrawingViewName As String
'Which text for which orientation
Select Case tmpView.Camera.ViewOrientationType
    Case ViewOrientationTypeEnum.kBackViewOrientation
        myDrawingViewName = "Back View"
    Case ViewOrientationTypeEnum.kBottomViewOrientation
        myDrawingViewName = "Bottom View"
    Case ViewOrientationTypeEnum.kFrontViewOrientation
        myDrawingViewName = "Front View"
    Case ViewOrientationTypeEnum.kIsoBottomLeftViewOrientation
        myDrawingViewName = "Iso - Bottom Left View"
    Case ViewOrientationTypeEnum.kIsoBottomRightViewOrientation
        myDrawingViewName = "Iso - Bottom Right View"
    Case ViewOrientationTypeEnum.kIsoTopLeftViewOrientation
        myDrawingViewName = "Iso - Top Left View"
    Case ViewOrientationTypeEnum.kIsoTopRightViewOrientation
        myDrawingViewName = "Iso - Top Right View"
    Case ViewOrientationTypeEnum.kLeftViewOrientation
        myDrawingViewName = "Left View"
    Case ViewOrientationTypeEnum.kRightViewOrientation
        myDrawingViewName = "Right View"
    Case ViewOrientationTypeEnum.kTopViewOrientation
        myDrawingViewName = "Top View"
    Case Else
        myDrawingViewName = ""
    End Select
'Chang if view orientation was found
If Not myDrawingViewName = "" Then
    'change drawing view name
    tmpView.Name = myDrawingViewName
End If
Next
End Sub
 bofore:
After using the macro:
The macro will change the name of the drawing view of all view on that sheet.
You can adjust the code and replace the names of the orientation with names you like.
Do you think, this would work for you?
Please use the button "Accept as Solution" if it works.
Dennis Ossadnik
Senior Technical Support Specialist
Message 3 of 24
When I paste this code into the iLogic Browser, I get an error message. I attached a screenshot image of it.
Message 4 of 24
Dennis.Ossadnik
Hi jbauer,
sorry, i was not aware that you wanted to use it in iLogic. The code above is for using as a macro in VBA.
I changed the code. Now you should be able to use it with iLogic:
Here is the code for iLogic:
Sub Main()
'active sheet
'every draring view
    Case Else
    End Select
End If
Next
End Sub
Thanks.
Dennis Ossadnik
Message 5 of 24
in reply to: Dennis.Ossadnik
Thanks for your help,
It's greatly appreciated.
Message 6 of 24
hi 🙂
work great, but is you have a section in your drawing, put side view in view label name????
Message 7 of 24
Hey Dennis, nice bit of code - works really well! Would it be difficult to modify it to ignore detail and section views? At the moment if you have any in the drawing they get modified too so you wind up with things like "DETAIL TOP" and "LEFT-LEFT SECTION"!
Cheers,
Kevin
Message 8 of 24
Dennis.Ossadnik
Hi Kevin,
could you please give this code a try:
VBA:
Sub IDW_OrientationToLabel()
'active sheet
    If tmpView.Type = kDrawingViewObject Then
            Case Else
            End Select
        'Change if view orientation was found
        End If
    End If
Next
End Sub
iLogic:
'active sheet
Dim tmpSheet As Sheet = ThisDrawing.ActiveSheet.Sheet
    Dim myDrawingViewName As String = ""
	If tmpView.Type = ObjectTypeEnum.kDrawingViewObject Then
            Case Else
            End Select
        End If
    End If
Next
Better now?
Dennis Ossadnik
Message 9 of 24
I have a 'twist' on this thread.
In the model representations you can create views. Is it possible to collect and use the name of the view in the title block of a sheet?
Message 10 of 24
Dennis,
im into a problem with your code. when i create the Left View it labels it as Front View and Front View as Right View.
Jeremy
Message 11 of 24
johnsonshiue
in reply to: jpchaisson
Hi! I guess you may need to check your Style setting and see if the view is based on model XY plane or Front. Open the idw/dwg file and go to Manage -> Styles Editor -> View Preference -> Front View Plane. Is it set to "From Model" or one of the origin planes?
Many thanks!
Software Test Engineer
Message 12 of 24
jpchaisson
in reply to: johnsonshiue
Johnson,
thank you, thats what it is my work computer is set to "XY" and not "From Model".
is there any way i can work around this leaving it set as "XY" ?
Jeremy
Message 13 of 24
johnsonshiue
Hi! I guess it may work but you will have to modify the code/rule so that it is changing the view you want to change. It can be a bit tricky.
Many thanks!
Message 14 of 24
I am using this Code and  its working well for me. I was just wondering if there was a way to update the rule so that the view label scale is overridden to show NTS for the ISO views? I have tried unsuccessfully.
Message 15 of 24
marcel.coufreur
Is it normal that you have to "Regenerate All Rules" before this takes effect? Or did i do something wrong?
Message 16 of 24
Hi @marcel.coufreur.  That should not be needed.  However, you may just need to add an extra line of code in there at the end to update the drawing document before you will see the changes.  If using an internal iLogic rule, you can use the line:
InventorVb.DocumentUpdate
...for that purpose.  Or if using VBA, you would use the variable for the document to update the document, similar to the following, where 'oDoc' is the variable that the DrawingDocument is assigned to:
oDoc.Update
There is also a setting within the Document Settings of drawings, on the Drawing tab, named 'Defer Updates', which may be on (checked).  When that is checked, some changes will require you to click the update button before the changes will show on your screen.
https://help.autodesk.com/view/INVNTOR/2022/ENU/?guid=GUID-1E32149E-D99B-4875-AEEC-849A36DE5023
Wesley Crihfield
Message 17 of 24
marcel.coufreur
@WCrihfield Where exactly do I write this? I'm not really familiar with Ilogic.
Message 18 of 24
Hi @marcel.coufreur.  I am not sure which of the codes above you may be trying to use, but I was referring to an iLogic rule, not a VBA macro.  If the code you are using starts with "Sub Main", and ends with "End Sub" (both unquoted), then you would need to put the code to update the document on a line just above the "End Sub".  But if your code does not have those terms enclosing the code, you could just put the line of code for updating the document at the very end, on its own line.  The "InventorVb.DocumentUpdate" line will only work within an iLogic rule, and will not be recognized in a VBA macro.  But both iLogic and VBA would both recognize a line like the following.
ThisApplication.ActiveDocument.Update
But to explain a bit more about the 'regenerate rules' thing, I am not sure there is an official online help page for this, but it is basically used to reconnect parameter recognition within internal iLogic rules.  What that means is, when the iLogic rule is an internal one (saved within an Inventor document), and you include the unquoted names of parameters (that exist within that same document) within that rule, that will cause the rule to be triggered to run any time the value of any of those parameters changes.  Sometimes either that triggering action, or the rule's ability to recognize that unquoted parameter name as representing a parameter gets broken some reason, clicking that tool will fix that association,  recognition, and triggering behavior.
Below is a link to some online help documentation that mentions this.
To Work with Rules in iLogic (and scroll to the heading "Run Rules", where this is mentioned)
You can also see a description of it when you hover your mouse over the Regenerate All Rules button for a while.
 When you use that tool, not only will it try to fix any problems, but it will run all of the internal iLogic rules within that document, and within any referenced documents too.  So be very careful using that tool while a large assembly may be open on your screen, and it may contain many other components that contain some internal iLogic rules.
Wesley Crihfield
Message 19 of 24
marcel.coufreur
@WCrihfield right now I have this.
Sub Main()
'active sheet
                myDrawingViewName = "Achteraanzicht"
                myDrawingViewName = "Onderaanzicht"
                myDrawingViewName = "Vooraanzicht"
                myDrawingViewName = "3D indruk"
                myDrawingViewName = "Linker zijaanzicht"
                myDrawingViewName = "Rechter zijaanzicht"
                myDrawingViewName = "Bovenaanzicht"
            Case Else
            End Select
        End If
    End If
Next
End Sub
  But It doesn't automatically update what am I missing?
Message 20 of 24
Hi @marcel.coufreur.  I slightly edit your code a bit in an attempt to maybe being able to help with the updating.  The terms 'ThisDrawing' and 'ThisApplication.ActiveDocument' can potentially be pointing to two different documents in certain situations, so eliminated both terms, and am now using the 'ThisDoc.Document' term to refer to the drawing document in the first two lines, then once I store that document reference to a variable (oDDoc), I use that same document variable at the end, to make sure I am working with the exact same document.  I also included a line to update the drawing sheet itself.  And I am using an Inventor API method of that document to update it directly, while accepting any errors that might arise, and continue.  I am also checking a related Document Setting within that drawing called Defer Updates, and if it is turned ON, that code will turn it OFF.  Give this a try, and hopefully it will update better for you.
Sub Main()
	If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then Exit Sub
	Dim oDDoc As DrawingDocument = ThisDoc.Document
	If oDDoc.IsModifiable = False Then
		MsgBox("This drawing is not modifiable.  Exiting rule.", , "")
		Exit Sub
	End If
	If oDDoc.DrawingSettings.DeferUpdates = True Then
		oDDoc.DrawingSettings.DeferUpdates = False
	End If
	Dim oSheet As Inventor.Sheet = oDDoc.ActiveSheet
	Dim oViews As DrawingViews = oSheet.DrawingViews
	For Each oView As DrawingView In oViews
		Select Case oView.Camera.ViewOrientationType
			oView.Name = "Achteraanzicht"
			oView.Name = "Onderaanzicht"
			oView.Name = "Vooraanzicht"
			oView.Name = "3D indruk"
			oView.Name = "Linker zijaanzicht"
			oView.Name = "Rechter zijaanzicht"
			oView.Name = "Bovenaanzicht"
		Case Else
		End Select
	Next 'oView
	'update the sheet
	oSheet.Update
	'update the drawing, True = accept any errors and continue
	oDDoc.Update2(True)
End Sub
...and by the way, that 'Defer Updates' setting can be found manually by going to the Tools tab > Options panel > click the Document Settings tool, activate the Drawing tab within that dialog, and there is a checkbox for that setting near the top left of that dialog.
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
