I'm looking for a 2" x 1" x 3/16" bar channel in the Content Center but I cannot find anything smaller than 3" x 1.41" x 0.17". I've been looking under Structural Shapes > Channels. Am I looking in the wrong spot? Am I missing content from the Content Center? Or does this just not exist in the Content Center?
Solved by cbenner. Go to Solution.
Check in here.
I think you will find what you are looking for. If you do need a custom size that you use all the time and need, you can create one and publish it to the CC.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!! :smileyvery-happy:
Might be missing something in my content center...but looking where the solution post points only leads me to flat bar...there's no "bar size" channel (smaller channels w/ 2 1/2" web or smaller).
2 1/2" channel is not available... but if you copy the library to a "read/write" or custom library you can add as many sizes as you want. you can even make some up... but I wouldn't recommend that. 😄
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
And I wouldn't want to...these are just common stock sizes from any steel supply. It's not like it's a custom part. It should be in the package.
I'm more curious how this issue was "solved" if the part isn't actually there.
Well, that is a good question. BTW, I was just needling you a bit about the weird sizes. Sorry.
Chris Benner
Last I looked, I could never find a standard for 'bar-sized' channels, let alone actual published dimensions. This maybe the main reason it is not in the CC: no tabulated data to give to the summer interns used to construct such minutiae not really of interest to the main programmers, let alone the sales team. I may be utterly wrong, but seems to me this 'mercantile' class of channel isn't really controlled and appears to be at the mercy of the various mills' whims.
