Inventor Forum
Banner arm FEA
4 REPLIES 4
CAD-One
415 Views, 4 Replies
Banner arm FEA
How do you run a stress analysis on the banner arm.
Would you recommend running as an assembly  or just the one arm?
What kind of load would you apply form a 90mph wind.
C1
Inventor Professional 2020
Vault Professional 2020
AutoCAD 2020
4 REPLIES 4
in reply to: CAD-One
Do the modelling of arms,pole, thyen creat thin Banner surface. assemble everything than assume Wind load as Static load,Counstraint the pole at bottom as Fixed joint
I hope you can able to see some stress at the intrusection of arm & pole
Kiran
CAD-One
Thanks I will try.
Any ideas what kind of static force would a 90 mph wind equal
C1
AutoCAD 2020
You apply as pressure of 90mpa or 90N/mm2 on the created banner surface
With rgds,
Kiran Kori
Application Engineer
+91 99000 40128 | kiran.s@mgenindia.com
MicroGenesis CADSoft Pvt. Ltd.
522, 33rd Cross | Jayanagar 4th Block | Bangalore | 560 011 | INDIA
Phone: +91 80 49200000 | Fax: +91 80 26641623 | Web:
www.mgenindia.com
http://www.mgen.in/signature/signature2.png
http://www.mgen.in/signature/linkedin.png
http://www.mgen.in/signature/facebook.png
http://www.mgen.in/signature/twitter.png
http://www.mgen.in/signature/autod.png
Mark.Downes
Hi CAD-One
if you google "INVENTOR SIMULATION handout_2038_MA2038"
Autodesk have a handout from Wasim Younis. It takes you though the equations for wind force on a pannel.
I attended his FEA class last year, it was very good.
Hope this helps
Cheers
Mark
Cheers
Mark
Inventor 2018, 3DS Max 2018, Vault 2018
