How do you run a stress analysis on the banner arm.
Would you recommend running as an assembly or just the one arm?
What kind of load would you apply form a 90mph wind.
Do the modelling of arms,pole, thyen creat thin Banner surface. assemble everything than assume Wind load as Static load,Counstraint the pole at bottom as Fixed joint
I hope you can able to see some stress at the intrusection of arm & pole
Kiran
Hi CAD-One
if you google "INVENTOR SIMULATION handout_2038_MA2038"
Autodesk have a handout from Wasim Younis. It takes you though the equations for wind force on a pannel.
I attended his FEA class last year, it was very good.
Hope this helps
Cheers
Mark
