Inventor General Discussion
Valued Contributor
albmopar
Message 1 of 10 (330 Views)
Ballooning in I assembly
330 Views, 9 Replies
08-28-2013 01:51 PM
I have several iterations of an assembly.  Specifically I have a base of a machine with different tooling for different products.  I generated the BOM by referencing the specific tooling I am trying to detail.  That worked.  But when I balloon, it references the main assemlby.  It won't let me redirect the source file to the tooling asm
I mistyped before.  Mcgyvr is correct.  The sub-assembly should be phantom and its components should be normal.
If you do this, this sub-assembly should be able to be ballooned in the top level assembly.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! :smileyvery-happy:
Cadmanto
Message 2 of 10 (327 Views)
Re: Ballooning in I assembly
08-28-2013 01:58 PM in reply to: albmopar
If you want to show the components the tooling assembly in your upper level assembly, what you need to do is in the tooling assembly go to the "Tools" tab
and make sure tis assembly is set to "Reference"
What this will do is show the components of this assembly in every assembly it is inserted into and not show the sub-assembly number.
Best Regards,
Scott McFadden
Inventor Professional 2014
(Colossians 3:23-25)
Valued Contributor
albmopar
Message 3 of 10 (320 Views)
08-28-2013 02:07 PM in reply to: Cadmanto
I got the refence thing down, but even though the BOM is tied to the sub assembly, the balloons are tied to the main assy.  So the only balloon I get is 19.
Cadmanto
Message 4 of 10 (266 Views)
09-23-2013 07:17 AM in reply to: albmopar
The parts list should be tierd to the main assembly showing the components of the subassembly allowing you to balloon the subcomponents.  If this is not happening that you need to check the ststus of the subcomponents to make sure they are not tagged "Reference" as well.
Best Regards,
Scott McFadden
Valued Contributor
albmopar
Message 5 of 10 (248 Views)
09-23-2013 08:57 AM in reply to: Cadmanto
I don't get the option to balloon the subassembly when I select balloon.  The subassembly is set to Normal, not phantom.  Am I missing something?
Cadmanto
Message 6 of 10 (242 Views)
09-23-2013 09:08 AM in reply to: albmopar
If you go to where I instructed you in my original posting, the sub-assembly should be "Reference" and all of its components should be "Normal".
Best Regards,
Scott McFadden
mcgyvr
Message 7 of 10 (236 Views)
09-23-2013 09:43 AM in reply to: Cadmanto
Its phantom not reference..
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
Valued Contributor
albmopar
Message 8 of 10 (229 Views)
09-23-2013 10:05 AM in reply to: mcgyvr
The subassembly is the one I am trying to balloon.  The sub assembly is changeover fixturing on a peener.  I have the peener set to reference and the fixturing set to Normal.  As shown in the BOM, I can choose the fixturing to fill out the BOM, but only have the option to balloon the whole assemlby, which only shows item 19, the fixturing.
Cadmanto
Message 9 of 10 (218 Views)
09-23-2013 10:54 AM in reply to: albmopar
Best Regards,
Scott McFadden
Valued Contributor
albmopar
Message 10 of 10 (208 Views)
09-23-2013 11:23 AM in reply to: Cadmanto
AH-HA  Thanks too all.
