Hey I am working in a .idw and need to move around my balloons. There seems to be a small grab handle on each balloon. Is there any way to make this a bit larger. It takes a few clicks of the mouse to actually grab it and move it.
Solved by Cadmanto. Go to Solution.
Chris,
What I do is when I hover over the balloon I wait until I get the square type symbol then select it.
This always works for me.
As far as a setting to enlarge the pickbox? Don't know of one. That might be something to do with your screen resolution setting.
Ok, I see. Thanks for the respones!
You can get the grab handles to show up larger. Go into Application Options and on the General tab there is a setting for Annotation Scale. Simply mak this number as large as you want to get the handles larger. This will also make a few other things larger, like dimensions in a sketch.
Andrew In’t Veld
Designer
thank you!
