I have searched but most of the posts I come across are very old. I am trying to get a drawing to auto balloon via the API or through iLogic. I have a parametric assembly that I control via a spread sheet. I can successfully use iLogic to suppress/unsuppressed parts in the assembly based on parameters from that spread sheet. The BOM in the drawing successfully changes along with the part suppression, my problem is I would like to have it auto balloon the assembly view in the drawing based on that BOM part list. I can balloon it manually when set to everything visible, then when stuff starts turning off the balloons detach and turn red. That is fine I can deal with that, but when I go back to a parameter set that turns those parts back on again the balloons will not reattach. I have been able to get them to attach by using the ActiveSheet.View("VIEW1").Balloons.Reattach function, but they just randomly attach to whatever. I have tried to get them to reattach by using the ActiveSheet.View("VIEW1").Balloons.AttachToComponent("example:1") function but it does not seem to do anything.
Any ideas?
Welcome to the forum.
I didn't go through this entire thread, but it seems to cover a lot. While I did not see auto-ballooning, you might find some useful tid bits.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
