I am a novice when it comes to inventor and i am trying to make my spin on a ballistic knife. instead of the classic trigger mechanism used i am using a peg/slot mechanism to fire. i need a peg less than .9 in in diameter that will slide in the "L" hole i made in the knife projectile. I would enjoy someone who could attach the peg so i can assemble it. Here are the files so you can mess with them. The cap attaches to the bottom of the handle. thanks in advance.
Many of your sketches are unconstrained and no dimensions?
What is the tap drill size for a 1.125-7 thread?
I recommend you start here http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
Once you have the parts dimensioned I can probably help out.
