Is there any chance I could get access to your library of ball valves? I have been trying to find dimensions to draw them myself but all I can find is flange diameter/bolt diamter/flange thickness, etc...
I am trying to find information for both flanged and threaded ball valves for use on fiberglass lines for oil and gas leases.
You could try https://grabcad.com/home
Might find something there for Inventor.
traceparts.net is another excellent source for cad models (2D and 3D). Doing a quick search of 'ball valve', turned up a slew of results! You just need to register (free and very little information required). Then you have instant access to the full library of Vendor supplied parts.
Thanks for the reply, I've been through that site a few times already, it seems that people on there only do one size of ball valve or so each, I was hoping to find a library done of all the same type. I was able to do butterfly valves based on dimensions I found online, but ball valves are a little different story.
Let me know what size, standards, etc... you require and I will see if I can find one on traceparts
Yeah I actually found quite a bit on there, unfortunately I am unable to import the files. I've tried several different configuration settings with what software/version combinations and every time, whether I use the import command or acisin commands it just does nothing... I get no errors and I get no part.
I tried getting a 2D drawing and just dimensioning it myself, but apparently it was the wrong type of flanged ball valve as the bolt pattern was WAY off. I need to get with my boss and get more information about the ball valves we use.
