Inventor General Discussion
Distinguished Contributor
lis_wang
Message 1 of 19 (869 Views)
ball pattern in BALL SCREW assembly
869 Views, 18 Replies
10-18-2012 12:33 AM
May I know how to pattern the ball in BALL SCREW assembly? The ball screw assembly is attached.
lis_wang
Message 2 of 19 (870 Views)
10-18-2012 12:34 AM in reply to: lis_wang
As the file is big, so I posted here in two messages.
JDMather
Message 3 of 19 (846 Views)
Re: ball pattern in BALL SCREW assembly
10-18-2012 05:29 AM in reply to: lis_wang
Really it depends on what you want to do with this.
The easiest solution is a curve driven pattern of Workpoints in the screw part and then use that pattern to place the balls in the assembly.
If your end goal is Dynamic Simulation then a bit more work is required.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
lis_wang
Message 4 of 19 (838 Views)
10-18-2012 06:17 AM in reply to: JDMather
I do not undertand what you said. Could you please pattern the ball inside the nut. I do not do the Dynamic Simulation.
JDMather
Message 5 of 19 (825 Views)
10-18-2012 06:44 AM in reply to: lis_wang
See Tips 43-47 here http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
and also
the slot and the ball are the same size (no allowance for clearance and manufacturing tolerance) - we can't make perfect parts in the real world.
and also
the circle sketch for the coil is not perpendicular to the start of the helix - therefore the slot is not round in cross-section and there is interference between the ball and the screw and nut.
Start with a Natural start condition (off the end of the part far enough that only the helix is cut or use a single line Coil to create a surface body coil to use with Sweep.  This will be needed to place and pattern the WorkPoints, so that is how I would do the part.
JDMather
Message 6 of 19 (820 Views)
10-18-2012 06:52 AM in reply to: JDMather
The blue "line" is your circle profile on edge view.
The purple curve is the Helix.
Notice that the blue line is not perpendicular to the start of the helix.
The orange "line" is a Workplane created perpendicular to the start of the helix.
very few people catch this mistake that results in incorrect geometry.
lis_wang
Message 7 of 19 (814 Views)
10-18-2012 07:14 AM in reply to: JDMather
I do not get what your mean. Is that possible give me the file, I take a look myself?
JDMather
Message 8 of 19 (808 Views)
10-18-2012 07:35 AM in reply to: lis_wang
I am using 2013 - so you would not be able to open my file even if I posted it.
In this image there are two circles - the 6mm circle you used with Coil to cut the face shown in orange.
I cut back overtop that feature (red) with a 5.99mm circle and notice that it cuts the sides more even though the circle is smaller.
My circle is perpendicular to the helix, yours is not.
I made a mistake earlier when I said one solution was Natural on the start of the Coil.  That is the default.  You would need a flat start to have the circle perpendicular to the coil curve.  But don't use that technique unless you start the Coil well off of the part, and in any case it will give you results that are harder to understand than simply doing a Coil surface of a line and using the edge of the surface body helix for a Sweep.
JDMather
Message 9 of 19 (799 Views)
10-18-2012 07:48 AM in reply to: JDMather
I just realized I left out some steps in that other document - see this one
http://home.pct.edu/~jmather/AU2007/MA105-1L%20Mather.pdf
lis_wang
Message 10 of 19 (693 Views)
10-18-2012 06:10 PM in reply to: JDMather
Could you please posted the file here? I will installed 2013 in another PC to try it.
