Inventor General Discussion
u067820y
Message 1 of 9 (2,367 Views)
Ball Joint Drawing/Model
2367 Views, 8 Replies
02-14-2011 12:11 AM
Hi All,
Does anyone have an engineering drawing with dimensions for a ball joint? A .ipt file of a ball joint actuator will be the best. Thanks all.
Open the attached 2011 model, then Activate Contact Solver on your system.
Distinguished Contributor
smjanows
Message 2 of 9 (2,325 Views)
Re: Ball Joint Drawing/Model
02-14-2011 09:44 AM in reply to: u067820y
What class is this for?
u067820y
Message 3 of 9 (2,240 Views)
02-20-2011 05:20 PM in reply to: smjanows
The use if just for viewing the inner assembly of a ball joint model. Purely to understand how the ball joint models work.
JDMather
Message 4 of 9 (2,235 Views)
02-20-2011 06:28 PM in reply to: u067820y
Should take about an hour to model up.  Are you still looking?
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
*Pro
Dennis_Jeffrey
Message 5 of 9 (2,174 Views)
02-21-2011 12:38 PM in reply to: u067820y
____________________________________________________________
Dennis Jeffrey, Author and Manufacturing Trainer, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert
Autodesk Silver Manufacturing Partner
Subscribe to the free digital "The Creative Inventor Magazine" now available at: http://teknigroup....
XP64 SP2, GeForce 9800GT-1GB, Driver: 6.14.12.7061, 8GB Ram, AMD Athlon II 3.2 Ghz
Laptop: Win7-64 Pro, 4GB, ATI Graphics on board, 2012 Ultimate, IV2011 or 2010 Pro, all SP's
Active Contributor
Namoi1
Message 6 of 9 (724 Views)
11-21-2013 01:33 PM in reply to: Dennis_Jeffrey
Dennis
can't use contact solver on a part like this, as there isn't any interference.  But there is still need to restrict the ball.
I got a problem though.  The way I've constrained it in this model works fine, but once I put it in a larger assembly make it flexible it goes somewhat haywire.
For starters I can remove the angle constraint, but on adjusting the flexible assembly the design doctor says there is an error in this sub assembly, drilling down to it and looking at the constraints shows no problem.  Hit the update button or rebuild, sometimes need to do this a couple of times, and the doctor goes away.
Reactivate the angle constraint and it sends my assembly flying all over the place.
Make me think I'm doing something wrong, but I can't figure it out.  The geometry of the top assembly means that the angle constrain and it's limits are virtually irrelevant, so can't see why the top assembly should fall apart like it does.
C-H.
using IV2015
C-H
JDMather
Message 7 of 9 (715 Views)
11-21-2013 01:59 PM in reply to: Namoi1
I would delete that angle constraint - place in assembly, set to Flexible and let the mating part restrict the degrees of freedom.
Active Contributor
Namoi1
Message 8 of 9 (705 Views)
11-21-2013 02:49 PM in reply to: JDMather
when you say the mating part, you mean in the top level ****. yes? if I got that right, how do you suggest I restrict the DOF, with a contact set, or with an angle constraint like the one in the sub ****. or something else again?
using IV2015
C-H
Active Contributor
Namoi1
Message 9 of 9 (704 Views)
11-21-2013 02:50 PM in reply to: Namoi1
don't know why but **** replaced **** with a full stop after it.
using IV2015
C-H
