What's your point? Thats not a 90 deg (right angle) tool path...Thats a tool path with a radius at the corners. and thats exactly how Inventor treats a right angle sweep path too. Notice how the resulting corners from yours and JD's sweeps are identical (and incorrect in the real world)
If you programmed that path into a cnc machine it would look different than what Inventor outputs as the resulting cut.
This is why all engineers/designers should spend time in a machine shop.
