Inventor Forum
Ball End Mill Sweep
45 REPLIES 45
Message 1 of 46
3273 Views, 45 Replies
Ball End Mill Sweep
Is there a way to do a clean sweep that imitates the shape a ball end mill? I'm trying to create a path that has 90 degree bends and whose end product looks like it was cut by a ball end mill. If there's a way to avoid sweeping the straight areas and then revolving the corners, I'd be happy to know.
Thanks!
45 REPLIES 45
Message 2 of 46
JDMather
Something like this?
Message 3 of 46
Could you please save in Inventor 2008 format?
Thanks...
Message 4 of 46
JDMather
No
Message 5 of 46
mcgyvr
and technically thats not the correct shape a ball end mill will leave. If you need that actual path/shape that a ball end mill will create you need additional steps besides a simple sweep.
see attached Edited by: mcgyvr on Nov 20, 2008 3:53 PM
Message 6 of 46
Could you save in IGES or STP format?
Did you use the REVOLVE function at the corners?
Thanks.
Message 7 of 46
mcgyvr
Yes you need to do a straight sweep first, then revolve (cut) at the end of the sweep to get the rounded end, then another sweep perpendicular into the center of the revolve.
So 2 straight sweeps and 1 revolve to make a right angle.
attached is the step file
Message 8 of 46
JDMather
>...and technically thats not the correct shape a ball end mill will leave
Here is the result I got in another SoftWare that will allow swept cut of one solid body through another.
Message 9 of 46
That's what I'm looking for. What software did you use to make that?
Message 10 of 46
Created this in Inventor 2008 using an extruded cut feature and a couple of fillets.
Steve
Message 11 of 46
mcgyvr
{quote:title=JDMather wrote:}{quote}
Well that other software is not correct either. The shape/lines at the corner should form a "Y" shape and not a "V". Get out a ball end mill and see for yourself. The file I posted above is exactly what will be produced when a ball end mill runs through it. Edited by: mcgyvr on Nov 21, 2008 8:41 AM
Message 12 of 46
The shape a ball end mill leaves in material at the corners depends on how the tool path is programmed, in JD's example the cutter is rolled around the corners, how the exact toolpath will be generated varies depending on the machine tool and whether cutter compensation is used or not.
Message 13 of 46
I get neither a "V" nor a "Y" using ProE
Message 14 of 46
mcgyvr
The OP requested 90 degree paths.
Cutter compensation has nothing to do with it. Cutter compensation is simply offsetting the tool to the left or right (or up or down for a horizontal path) from the programmed path.
CAD programs like inventor cannot duplicate the proper shape with a simple sweep because the profile for the sweep is 2d and set to follow the path so when it gets to a corner it locks the inside edge of the profile and revolves the profile 90 degrees. This is NOT real world. What I posted IS correct and the only shape a ball end mill will make when programmed to do a right angle path.
Why the other program that JD used did not show the correct path makes me think that even though he swept what looks to be a 3d profile I believe the program is still taking a 2d shape from that 3d "tool" and sweeping it identical to how Inventor does it. I would be curious to see if he didn't do a rectangle path and stopped the tool in the middle of the part will it leave a rounded shape at the end or square like inventor will.
Message 15 of 46
> 90 degree bends
Message 16 of 46
Ok. Now my ears are pricked.
Since when does Solidworks have a swept volume function?
Link to an article or description?
Message 17 of 46
mcgyvr
What's your point? Thats not a 90 deg (right angle) tool path...Thats a tool path with a radius at the corners. and thats exactly how Inventor treats a right angle sweep path too. Notice how the resulting corners from yours and JD's sweeps are identical (and incorrect in the real world)
If you programmed that path into a cnc machine it would look different than what Inventor outputs as the resulting cut.
This is why all engineers/designers should spend time in a machine shop.
Message 18 of 46
JDMather
Added in r2008. I defined my path at the side of the tool rather than the centerline of the path. I included a very small radius (.001mm) in the 90° corners of the path.
Message 19 of 46
OP: "a path that has 90 degree bends"
_________________________________________
wrote in message news:6077110@discussion.autodesk.com...
Message 20 of 46
In that instance Pro/E is extending the surfaces to intersection.
