Inventor Forum
Backup folder for templates etc.
3 REPLIES 3
MikeDiyer
457 Views, 3 Replies
I have created design templates, styles, etc. and want to add them to our server and re-direct all users to these locations. However, what happens if the server is unavailable? ex: took workstation home
I understand that the folders won't be accessible, but I think Inventor should re-direct to the default folder, instead it just gives an error. Would the user have to go into application options and change all the file locations??
Thanks, Mike
3 REPLIES 3
mcgyvr
in reply to: MikeDiyer
You could simply setup an "At Home" project that points to the proper locations..
How I've set up to work at office and home, I have 2 appilcation option XML's for home and office for quick switching. Then a local project and all my templates, design  data, and stuff copied to a second SSD drive in my laptop. Content center items are a little tricky and can be a pain in the rear.
When I go home, import Home.xml application options and switch to local project and I'm good to go.
blair
I use a program called ViceVersa Pro to sync my work and home offices and use a USB drive to hold the files.
Delta Tau Chi ΔΤΧ
