Inventor Forum
Background error in iam file
6 REPLIES 6
Albeda8
277 Views, 6 Replies
I have interesting problem with background in one *.iam file and only on one PC (viz. picture bellow).
Any ideas?
Thank you
Student
Martin
6 REPLIES 6
Cadmanto
in reply to: Albeda8
Hi Martin,
With you saying this is only happening in one file that eliminates a custom background setting.
Where did you get this file?  Is there anything in the browser that indicates this is a component?
Can you highlight it?  If so what highlights in the browser when you do?
What version are you running?  Can you post the file?
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
cbenner
This looks like someone was messing with the view settings.  Check View tab, Appearance panel.  See pic:
The view you see looks like the "Plain Room".  You can change the backgrounds here, or go back to default.  If you see this everywhere, you mught want to check your template files.
Hope this helps.
AutoCAD 2013; AuoCAD Electrical 2013; IV 2013 Professional: Tube and Pipe, Frame Generator, Content Center; Vault Professional 2013: Client, ECO
My Blog, pretty weak I know, but I'm just getting started. 😄
http://cbennertipstricks.blogspot.com/
Cadmanto
in reply to: cbenner
Chris,
Never played with that setting before, but after trying it I can see that might be the issue.  Looks to be custom though.
Best Regards,
Scott McFadden
cbenner
in reply to: Cadmanto
Some of them are pretty cool for quick renderings.  I did one of our models that was an R&D project in the "Old Warehouse" background, rendered with shadows and reflections and used the "realistic" setting on it.  It looked really sharp for show & tell.
Cadmanto
They are.  I was trying a few.  Pretty cool to place my equipment in the middle of an intersection in the desert.  Smiley Very Happy
I will have to try and import my own background to show the powers at be even more functionality to play with in Inventor.
Best Regards,
Scott McFadden
Albeda8
Hi again,
thank you for reply. It was view style in Inventor. Now its everything OK.
Best regards
Student
Martin
