I have interesting problem with background in one *.iam file and only on one PC (viz. picture bellow).
Any ideas?
Thank you
Student
Martin
Solved by cbenner. Go to Solution.
Hi Martin,
With you saying this is only happening in one file that eliminates a custom background setting.
Where did you get this file? Is there anything in the browser that indicates this is a component?
Can you highlight it? If so what highlights in the browser when you do?
What version are you running? Can you post the file?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
This looks like someone was messing with the view settings. Check View tab, Appearance panel. See pic:
The view you see looks like the "Plain Room". You can change the backgrounds here, or go back to default. If you see this everywhere, you mught want to check your template files.
Hope this helps.
AutoCAD 2013; AuoCAD Electrical 2013; IV 2013 Professional: Tube and Pipe, Frame Generator, Content Center; Vault Professional 2013: Client, ECO
My Blog, pretty weak I know, but I'm just getting started. 😄
http://cbennertipstricks.blogspot.com/
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Chris,
Never played with that setting before, but after trying it I can see that might be the issue. Looks to be custom though.
Some of them are pretty cool for quick renderings. I did one of our models that was an R&D project in the "Old Warehouse" background, rendered with shadows and reflections and used the "realistic" setting on it. It looked really sharp for show & tell.
Chris Benner
They are. I was trying a few. Pretty cool to place my equipment in the middle of an intersection in the desert.
I will have to try and import my own background to show the powers at be even more functionality to play with in Inventor.
