No matter what settings I chose in my Windows setting this panel is always BLACK with INVISIBLE text until clicking on something with in it then anything below that item is invisible such as content center files etc.
Is anyone else seeing this, How did you fix it???
Solved by Mark.Downes. Go to Solution.
Have you tried a different theme/color scheme in Windows?
See if;
Control Panel =>Appearances and Personalization => Personalization => Window Colour and Appearance
Click in the "Window Text" and change the colour to your preference, I use a soft green colour as it is easier
on my old eyes when using word or excel.
Hope this helps
Cheers
Mark
Inventor 2014
The give solution worked BUT we should not be seeing the this problem within Inventor this needs to be fixed as some of us need or can't see specific colour setting due to colour-blindness and/or various filters on optical lens's that we need.
