Inventor Forum
Background Color
5 REPLIES 5
mcrump28210
75445 Views, 5 Replies
Background Color
I need to turn the assembly background pure white for illustrative purposes.  Is this possible in Inventor 2013
Michael Crump
AutoCAD 2013
Inventor 2013
Windows Pro 7 x64
Asus Sabertooth X58
Intel Core i7 960 @ 3.2 GHz
24 GB ram
5 REPLIES 5
MariaManuela
in reply to: mcrump28210
Hi
Absolutely yes.
Tools \ Application Options \ Color... then select Presentation shceme with 1 color background
Asidek Consultant Specialist
www.asidek.es
mcrump28210
in reply to: MariaManuela
Perfect!  Thanks so much!!
Michael Crump
AutoCAD 2013
Inventor 2013
Windows Pro 7 x64
Asus Sabertooth X58
24 GB ram
MariaManuela
In addiction you can install the Autodesk plugin called Screen Shot for Inventor.
About:
Screenshot can be used with Inventor to simplify image capture of the entire Inventor application window, the graphics view of documents open within Inventor, or parts of the graphics screen. You can also remap the background to white and the foreground to black, and convert the entire image to grey scale, as well as sending the captured image directly to a printer. This plug-in was first published as an ADN Plugin of the Month: http://labs.autodesk.com/utilities/ADN_plugins. The plug-in has been provided with the complete source code needed to build the application, with the intention of encouraging users of Autodesk software to use programming to tailor the products they use to their specific business needs.
http://apps.exchange.autodesk.com/INVNTOR/Detail/Index?id=autodesk.appstore.exchange.autodesk.com%3a...
www.asidek.es
Hi mcrump28210,
Here's another tip on the subject:
http://inventortrenches.blogspot.com/2012/09/inventor-background-color-as-white.html
I hope this helps.
Curtis
when I opened the link to your website it came up as malware, just a ps if some infected ad has found its way on to your site
AUTODESK EXPERT ELITE
MariaManuela
122 Kudos
70 Solutions
Re: Background Color
09-06-2012 09:31 AM in reply to: mcrump28210
Hi
Absolutely yes.
www.asidek.es ----------- this was the site that had malware, well a redirect to a malware page.
s
Ozzie Sheppard
-860-532-0687-
Hp z800/w duel x5690 @ 3.47 ghz 12 core with hyper threading
nvdia quadro k6000 w/2 la2205wg 2 tb ssd raid
196gb ddr3 ram and a pci memory boost.
