Inventor Forum
back in the day, degrees of freedom
6 REPLIES 6
accu-cad
174 Views, 6 Replies
I seem to remember a RMB when selecting a part that would illustrate a degrees of freedom of a part in an IAM. Did this disappear or am I just not remembering correctly. I have a part that is critical (well that is overstating it a bit) to its location. I feel that it can not move (due to its contraints) but the not "movable" symbol will not come up when I try to pull it in the IAM so I tried to look where it can move. I was sure I use to RMB and find a degrees of freedom option and then a symbol used to come up on the part indicating the way that the part might be able to move. Any ideas?
6 REPLIES 6
in reply to: accu-cad
You can turn it on in the View menu. Unconstrain
something and it should show an arrow in that direction.
~Larry
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I
ideas?
View/Degree of Freedom.  If the icon does not
appear on a part it has no DOF...
Sean Dotson, PE
href="http://www.sdotson.com">http://www.sdotson.com
Check the Inventor
FAQ for most common questions
href="http://www.sdotson.com/faq.html">http://www.sdotson.com/faq.html
I
ideas?
accu-cad
thanks
accu-cad
that only makes perfect sense thanks
Select the component, RMB, select Properties,
select Occurrence, check the Degrees of Freedom check box to display the DoF for
that selected part (otherwise as others have mentioned, View menu will toggle
the DoF on/off for all of the (first-level) components in the
assembly.
G
accu-cad
Oh so it is burried under properties. That is ok too. I don't use it often so either method of finding it is good. Thanks "G"
