In previous versions when you hovered over an invisible axis in the browser you could see the whole line in the model. Now you just get the end points displaying as yellow circles and it can be quite difficult to see where the line is. What's the point of this change? Is there a way to get the old behaviour back?
Solved by mbenoy. Go to Solution.
It's an SP1 problem. See http://forums.autodesk.com/t5/Autodesk-Inventor/Workfeatures-Edge-View-Issue-Inv-2012-SP1/td-p/31428...
It's taking longer than I thought for a hotfix to fix what SP1 broke.
