If you are using Animator and want a smooth animation, set the frame
rate to 15 or higher and increase the number of step to match. Say you
have a conveyor belt that you want see moving at 60" per second at a
frame rate of 20fps. This would require the distance to be 3" per
frame. If you wanted a 5 second AVI, it would require 100 frames
(steps). The distance traveled would be 300" so if the Start was 0,
then the end would be 300.
If the AVI has already been created, you would need to post process it
to change the frame rate. Camtasia can do this.
acesfull wrote:
> What is the best way to slow down the animation ie make something that
> last 5 seconds when recorded take 15 seconds when recorded? Also how
> do I get better resolution for the avi?
