Inventor General Discussion
Distinguished Contributor
0 Kudos
Post 1 of 15
Autosave
204 Views, 14 Replies
04-02-2009 01:27 PM
Why is there no autosave or recovery in Inventor? And if there is, how do I turn it on. I've lost a lot of valuable work time due to inventor shutting down on me all the time. I know to save, save, save, but sometimes you get lost in the work and the next time you blink is when you get the I'm sorry, inventor has caused a serious error and needs to shut down, and by then it's too late. Please help!
*Blair Stunder
Post 2 of 15
Re: Autosave
04-02-2009 01:45 PM in reply to: jlackey4740
There is a timer function is IV2010 to remind you.
You can set the reminder time.
IV2010pro-suite
Dell 670 dual Xeon - 3.2
3gb memory,
SCSI320-15k rpm
XP-Pro, sp3
Quadro FX3400: Driver: 182.08
Direct3D
SpacePilot Rel V: 3.6.11 Dvr V: 6.6.4 Firmware 3.12
AVG 8.5
Why
Please help!
*Dennis Jeffrey
Post 3 of 15
Re: Autosave
04-02-2009 01:46 PM in reply to: jlackey4740
No autosave. I can count the crashes on my system in the past
year with less fingers than on one hand. You need to troubleshoot WHY you are
having the frequent crashes.
Dennis Jeffrey, Autodesk Inventor Certified
Expert
Autodesk Manufacturing Implementation Certified
Expert.
Instructor/Author/Sr. App Engr. Tel. (260) 399-6615
AIP 2008 SP3,
AIP 2009-SP1 PcCillin AV
HP zv5000  AMD64 2GB - Geforce Go 440, Driver:
.8185
XP Pro SP3, Windows XP Silver Theme
href="http://teknigroup.com">http://teknigroup.com
*Blair Stunder
Post 4 of 15
Re: Autosave
04-02-2009 01:49 PM in reply to: jlackey4740
My number one reason for crashing, creating new
parts within an IAM and not do the initial save.
IV2010pro-suite
3gb memory,
SCSI320-15k rpm
XP-Pro, sp3
Direct3D
AVG 8.5
past year with less fingers than on one hand. You need to troubleshoot WHY you
are having the frequent crashes.
Expert
Expert.
AIP 2008
SP3, AIP 2009-SP1 PcCillin AV
Driver: .8185
0 Kudos
Post 5 of 15
Re: Autosave
I couldn't count the times it's crashed on all my fingers and toes in the last three weeks. I always hit send report, but I really don't know how to trouble shoot it as far as why it keeps shutting down.
*Dennis Jeffrey
Post 6 of 15
Re: Autosave
04-02-2009 01:52 PM in reply to: jlackey4740
Post the information requested here....
Expert
Expert.
AIP 2008 SP3,
.8185
*William Wang \(Autodesk\)
Post 7 of 15
Re: Autosave
04-08-2009 04:57 AM in reply to: jlackey4740
Could you please provide dataset and the steps to reproduce the crash? My
mail address is bo.wangATautodesk.com. This will help a great deal to look
into the crash issue that you are facing.
William (Bo) Wang
Autodesk Inventor
Development Team
0 Kudos
Post 8 of 15
Re: Autosave
04-08-2009 06:28 AM in reply to: jlackey4740
The problem is that there is no particular dataset that causes the crash, so at the moment I can't even think of one in particular. However, what I can say at the moment us that it is usually larger assys that have several sets of flexible subassys, that may have flexible assys in them as well. For instance, I have an oven door assy, and then in that assy I place a subassy that contains a fan and an electrical harness. The fan will be constrained to the door, but harness will not be since I need to move it once I place the door into the main oven assy, so I make the fan assy flexible within the door. Then, I insert the door assy into the top level oven assy, and make the door assy flexible so I can then move the harness in the door to the location in the oven wherre it needs to be showed. So, in addition to the door assy, I will usually anywhere from 5 to 10 other subassy withiin the top level that will also be flexible. At this point is where I begin having issues with inventor locking up when placing constraints, especially if you accidentally place a constraint and it is conflicting with another one. When that happens, I've sat and waited for an hour for the program to update the constraint, just for it to tell me the constraint is bad, and then crash shortly thereafter. I'm beginning to suspect that it may be a memory issue, but I am not sure.
J Lackey
XP PRO SP2
INTEL CORE 2
2.66GHz 3.25GB RAM
INV 2008 SP 3
1 Kudo
Post 9 of 15
Re: Autosave
04-08-2009 09:45 AM in reply to: jlackey4740
How "old" is your Windows installation?
I was having the same problem with IV2009, far more crashes than as far back as I can rememeber (IV5.3!!!) So I took the bull by the horns, wiped my hard disk, installed everything again and now the stability is back to normal. It's gone from probabaly three crashes per day to 1 in 2 weeks and even then I knew I was doing something a bit naughty anyway that was asking for a crash!
I was getting a lot of disk activity and then IV2009 just disappearing.
It may well be worth leaving MemTest running overnight but I bet a nice clean Windows installation will sort it out.
Cheers,
--Rob Singlehurst
IV2009 SP1
Dell Precision PWS690
Quadro FX3500
DirectX 178.46
Spaceball 5000
Intel Xeon 3GHz
2GB RAM
WinXP Pro SP3
Cheers,
--Rob Singlehurst
IV2015 SP1 Update1 64bit
Dell Precision T7500, Geforce GTX 970, DirectX11 344.65
SpaceExplorer 4.04, 3DxWare 3.12.2
Twin Intel Xeon E5506 2.13GHz, 12GB RAM, Win7 Pro SP1 64bit
*Expert Elite*
2,129 Kudos
Post 10 of 15
Re: Autosave
04-08-2009 10:03 AM in reply to: jlackey4740
Good point. Our IT re-ghosts (is that the right term) our hard dirves every semester and I don't see that many crashes from all our users put together.
I was having trouble on my personal machine between r2008 and 2009 and finally bit the bullet and spent most of a day cleaning it up. Aftwards Inventor was very stable.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
