hi,
I was thinking that it would be nice if the comments on the Vault check in was automatically updated with the revision history (for the current revision).
For example;
check out drawing.dwg
amend
update rev history - eg. Diameter dim added
check-in drawing.dwg
- at the bottom of the check-in splash screen the comments section is automatically populated with Diameter dim added
Is this possible? perhaps with a bit of ilogic? - its all to easy to just click through the screen and not add any comments!
Cheers.
Solved by mdavis22569. Go to Solution.
on thinking further......perhaps adding a button on the Vault Check-In dialog to allow you to update with the rev history if desired would be better.
I guess sometimes you may not want to update with the rev history - if you check out to amend a typo for example.
any comments would be appreciated
I posted it on the Vault forum and someone said that it is possible with Vault Pro.....but alas, I only have Vault Basic.
So guess I'll have to continue to wenter data manually!
