I think I may have queried this before, but if I did it was ages ago.......
Currently when creating a multi-sheet drawing I start by opening standard.dwg as usual and as usual the rev history table is situated in the correct place.
When add new sheet(s) however, the rev history table is not on these new sheets. Therefore I have to manually add the table to the sheets. This may only be a couple a mouse clicks...but its a couple I'd rather not make!
Is there a way to place the table on newly created sheets?
